A device’s resistance to water, splashes and dust is not a permanent feature and tends to decrease with normal wear. Since our devices are preowned products, unfortunately we cannot guarantee that the IP67 or IP68 certification remains valid.
To prevent damage from liquids, we recommend you avoid the following:
- Swimming, bathing or going to the sauna with your phone.
- Exposing your device to water, for example while taking a shower, swimming, wakeboarding and so on.
- Intentionally immersing the device in water.
- Using the device in temperatures that are not within the recommended range or in extremely humid conditions.
- Disassembling the device or removing screws from the device.
Please note that this list is only an example and not exhaustive. If your device sustains water damage, unfortunately your warranty is voided. Our warranty policy is like Brand's own policy, which does not cover water damage to the phone. If water ends up inside of the phone, the internal components will be damaged beyond repair.
