What is 100% battery health
Battery health
For iPhone 6 and later, iOS 11.3 and later add new features to show battery health and recommend if a battery needs to be replaced. These can be found in Settings > Battery > Battery Health.
All rechargeable batteries are consumables and have a limited lifespan—eventually their capacity and performance decline such that they need to be replaced. As batteries age you will be experiencing more noticeable battery and performance issues. A new replacement battery completely changes your experience.
Related Articles
Do you replace the battery of every phone?
Every device goes through Battery capacity check to receive and hold a charge and load cycle count, In these tests if any battery doesn’t function as per our standards it is replaced. Although we could renew devices without changing the battery but ...
What if your iPhone is running slow ?
Check your network conditions Many apps require an internet connection for their content and other functionality. If the network that you're connected to is congested — for example, at an event with many people using the same network — apps might ...
What if your iPhone touch won't charge ?
If your battery won't charge or charges slowly, or if an alert message appears, learn what to do. Plug into power To charge your device, follow these steps: Connect your device to the USB cable that comes with it. Plug into one of these three power ...
WHAT IS NOT COVERED BY THE WARRANTY ?
Any mechanical or electrical breakdown that results in its inability to function due to normal wear and tear or accidental damage from handling. Non-operating and cosmetic defect to the Device such as defect to paintwork, Product finish, dents or ...
